Dashboard removal to remove mk4 escort door?
Old 28-07-2011 | 09:37 PM
auldy's Avatar
auldy
Default Dashboard removal to remove mk4 escort door?
Hi, does the dashboard have to be removed to gain access to the top 2 13mm bolts on the o/s door on a mk4 escort?
cheers,auld
Old 28-07-2011 | 09:59 PM
studabear's Avatar
studabear
not if you knock the pin out on the top hinge
Old 29-07-2011 | 12:45 AM
WENNY's Avatar
WENNY
no and the pins probs wont come out.
bottom bolts are easy and top ones take the clocks out if you cant get in
Old 29-07-2011 | 10:47 AM
Turbosimpsons's Avatar
Turbosimpsons
you should be able to get up to the bolts from below.
Old 29-07-2011 | 11:26 AM
Danwood79's Avatar
Danwood79
Why don't you remove the bolts on the chassis rather than the door?
Vincereese
01-06-2023 10:14 AM
Vincereese
18-08-2015 04:57 PM
Vincereese
16-08-2015 07:38 PM
track.focus'd
12-08-2015 06:53 PM
no1trancefan
04-08-2015 01:48 PM
Quick Reply: Dashboard removal to remove mk4 escort door?
