efi conversion flywheel fitted ???
Old Jul 2, 2010 | 05:03 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
Default efi conversion flywheel fitted ???
right i just fitted a flywheel from a 3i efi to my s2 engine
the engine is timed up at tdc crank and cam
fitted the flywheel and the missing tooth on the fly sits about 60 deg before basicly it lines up with the edge of the front sump
sorry for the shit description lol
IS THIS CORRECT ?????
Old Jul 2, 2010 | 08:32 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
any 1
Old Jul 2, 2010 | 08:50 PM
andy130's Avatar
andy130
il post apic of a efi flywheel in a min
Old Jul 3, 2010 | 11:36 AM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
dont realy need a pic mate
i just need to know where missing tooth on the flywheel should be when the cranks at tdc ?
thanks
tommy
Old Jul 4, 2010 | 06:07 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
some one must know
Old Jul 4, 2010 | 06:11 PM
studabear's Avatar
studabear
I thought the flywheel bolts are offset so it will only bolt on 1 way
Old Jul 4, 2010 | 06:16 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
they will only bolt one way. the missing tooth sits at 90 befor tdc as its a 36-1 trigure wheel on fiesta turbo engines(flywheel) there is a tooth every 10 degrees so your missing tooth will be 9 teeth btdc iirc
Old Jul 4, 2010 | 09:42 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
Originally Posted by clarke5700
they will only bolt one way. The missing tooth sits at 90 befor tdc as its a 36-1 trigure wheel on fiesta turbo engines(flywheel) there is a tooth every 10 degrees so your missing tooth will be 9 teeth btdc iirc
your the man ....thats just what i needed to hear
thanks
tommy
Old Jul 4, 2010 | 11:40 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i have my megasquirtset for tooth number 1 being at 80degrees after TDC.
same as everyone else with a ford efi setup.
so 90 degrees for the missing tooth would be right.
Old Jul 5, 2010 | 10:00 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
cool mate yes its for ms thats cool il check my spark settings im pretty sure its set to 80
also cheers for the offer of the pick up sens ... i think i have sourced one but unsure if the correct one so i may still be in touch lol
tommy
EoinXR3
Sep 7, 2015 05:44 AM
Dahl88
Aug 22, 2015 08:16 PM
marky_g
Aug 15, 2015 10:43 AM
druidgetafix
Aug 15, 2015 10:22 AM
Caddyshack
15
Aug 4, 2015 08:50 AM
