Zetec Turbo
Old Jan 18, 2005 | 01:59 PM
carlosl's Avatar
carlosl
Default Zetec Turbo
I'm building a 2L zetec turbo and am not sure on the which head bolts to use I only want to run about 1 bar boost are the standard head bolts ok to use or will i need uprated ones.
thanks
Old Jan 18, 2005 | 03:09 PM
scooby8272's Avatar
scooby8272
STD will be fine upto a bar
Old Jan 18, 2005 | 06:16 PM
carlosl's Avatar
carlosl
thanks for the reply - are there any uprated ones that I can use as I don't want to push the standard ones to the limit?
Old Jan 18, 2005 | 08:00 PM
scooby8272's Avatar
scooby8272
Get a set of ARP's
From Burton's etc etc
Old Jan 19, 2005 | 09:23 AM
PhilM's Avatar
PhilM
PassionBMW.com Member
Standard Ford
Old Jan 20, 2005 | 10:53 AM
carlosl's Avatar
carlosl
do you know what the maxium boost the standard ford ones are safe to run?
thanks
Old Jan 21, 2005 | 05:59 PM
scooby8272's Avatar
scooby8272
14psi ish
Old Jan 21, 2005 | 07:39 PM
carlosl's Avatar
carlosl
Ok, thanks.
robnock
21
May 13, 2019 05:29 PM
robnock
Aug 22, 2015 10:51 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
