1.8 in 1.6 focus
Old May 25, 2010 | 03:54 PM
jools123's Avatar
jools123
Default 1.8 in 1.6 focus
im lookin at buying a complete running 1.8 on a s reg to rob everything to put in a 52 reg 1.6. has anyone done this before and how much work is involved. Any replys gratefully recieved
Old May 25, 2010 | 06:00 PM
oldford's Avatar
oldford
Engine ecu could be a problem. Wonder if it will fit because it's a lot older than the car.
Old May 25, 2010 | 06:08 PM
mercgrey's Avatar
mercgrey
wouldnt of thought it a problem tbh there both mk1 focus iirc? and even if there is a difrence you have the 1.8 loom to match ecu etc out the donor....... easy mate
Old May 25, 2010 | 06:19 PM
dazzabhoy's Avatar
dazzabhoy
my mate has just done the same conversion but from mk1 to mk2 focus,
its straight forward, use the 1.8 engine looom, ecu, key, and reluctor ring, match the wiring and away you go
Old May 26, 2010 | 12:28 PM
martysmartie's Avatar
martysmartie
There is no difference in the cars at all both are MK1 Focus with the later being a facelift, as said you will need the ECU and the transponders from the key from the 1.8 to fit into the other keys.
Martin
Old May 26, 2010 | 12:58 PM
LukeDaisley's Avatar
LukeDaisley
but why a 1.8 and not the 2l??
Old May 26, 2010 | 09:00 PM
JesseT's Avatar
JesseT
I have both a 1.6 and a 2.0 mk1 STW Foci at the moment, and to be honest, I'm a fan of the 1.6 engine. The 1.8 wouldn't have the benefits of either.
The 1.6 isn't the most powerful engine in the world, but you gain very little with the 1.8. The 1.6 on the other other hand has a better mileage, it's much more compact, much ligther, quieter, etc...
Old May 27, 2010 | 09:36 AM
percybigun's Avatar
percybigun
Twistin me melon man
pmsl quieter
liamT74
Sep 23, 2015 10:24 PM
pie-face
Sep 15, 2015 10:43 AM
talon1
Sep 15, 2015 10:27 AM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
