stage three cossie wont rev
Old Mar 18, 2004 | 07:08 PM
Default stage three cossie wont rev
i have a stage three 4x4 cossie and it wont rev beyond about 5500.the car has a t34,greens.3bar map sensor and an ahmed bayjoo chip and pectal board.runs fine and pulls like a train but feels like it is hitting a limiter.any ideas?
Old Mar 18, 2004 | 09:27 PM
Dave McB's Avatar
Dave McB
is the limiter no about there anyways?
Old Mar 19, 2004 | 07:22 AM
Guinnless's Avatar
Guinnless
Plugs?? Limiter is at 6800.
Old Mar 19, 2004 | 10:37 AM
plugs have been changed,ones that are in it are proper motorcraft motorsport plugs,not sure what the number is.the only things that are not ford are the plug leads.could they cause it?
Old Mar 19, 2004 | 11:52 AM
Guinnless's Avatar
Guinnless
What gaps on the plugs and what boost are you running?
Non-Ford leads are shite.
Old Mar 19, 2004 | 12:54 PM
When you say it only revs to 5500, does the engine just bounce (like its hitting the limiter) or is it more like hitting a brick wall?
Old Mar 19, 2004 | 03:41 PM
plug gap is set at 26 thou,running 24psi.
when it hits 5500 it is not like hitting a limiter,it just doesn"t want to rev any more as if there is no power above that.
cheers dangerous
Old Mar 19, 2004 | 06:15 PM
Tony Ryan's Avatar
Tony Ryan
Sounds like youve a split in a hose or something , the boosted air sounds like its getting out as boost rises .
Old Mar 19, 2004 | 06:25 PM
cheers for that,will have to have a look
Old Mar 20, 2004 | 10:24 AM
iv got one that does exactly the same as this mate! let me know if you sort it and il
try it on mine......
Old Mar 20, 2004 | 12:47 PM
Milko's Avatar
Milko
Mine hits the boost limiter at 6200, running 24psi also with bajoo software. It would seem Bajoo is putting these "safeguards" in his chips. But I aint sure, could be sumat else.
Old Mar 22, 2004 | 04:19 PM
not a split boost hose.any other ideas?would a weak coil or fuel pump cause it?
Old Mar 23, 2004 | 09:55 AM
Guinnless's Avatar
Guinnless
I think you need to get it checked by a pro.
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
A.t.p
Sep 29, 2015 05:04 PM
cossie330
Sep 27, 2015 04:13 PM
