juddering!!!
Old May 19, 2010 | 11:43 AM
alexno1dj's Avatar
alexno1dj
Default juddering!!!
any ideas why my escort zetec seems to judder (not missfire) when i pull away from junctions? If just left to tickover it eventually cuts out as revs drop too low. Any ideas ?
help much appreciated.
Old May 19, 2010 | 04:54 PM
I'd check the CO, if running really lean could do this, the fave areas are the PCV valve and the "T" piece at the rear of the head, both pennies to fix.
Old May 20, 2010 | 12:25 PM
alexno1dj's Avatar
alexno1dj
hi mate
ok well ive just changed the lambda sensor as id been driving around with a broken 1 for weeks. But it wasnt a new one (scrappies)
Where is the pcv valve? Is that the one on air intake near throttle body? cheers
sorry i now realise a PCV is crankcase ventilation, where would i find it?
Old May 20, 2010 | 04:38 PM
It's at the front of the engine hidden between the exhaust manifold and block, unless they've moved it again!!
Old May 20, 2010 | 04:42 PM
alexno1dj's Avatar
alexno1dj
ok will have to check that then, cheers
Old May 20, 2010 | 04:48 PM
alexno1dj's Avatar
alexno1dj
any other suggestions while im on here? just so i can try a few to make sure
martynhomer01
14
Sep 23, 2015 12:23 AM
Mark Mawson
Aug 31, 2015 07:09 PM
gabbo
Aug 28, 2015 03:56 PM
Archiejay
Aug 12, 2015 12:07 PM
tommylommykins
Ford Fiesta
Aug 8, 2015 08:01 PM
