xr3i help needed novice at work!!
took the project car to get the tracking done and noticed the nearside wheel is pushed further back in the arch then offside. Looks like its been curbed badbly and control arm has been replaced. Would damage to the anti roll bar cause this?
Easiest way to check arb if off the car is draw around it with a marker pen on the pavement etc, then swap it around end to end, this will soon show if it's bent, if only very slightly bent pack whichever side is needed with a few washers on the arb before putting the large washer either side of the bushes to even wheel position up, it's free and it works safely.
JoeyBoyden
04-01-2024 02:36 PM
marky_g
15-08-2015 10:43 AM
