focus st with fault code C1288 (esp fault) need help
Old May 3, 2010 | 06:48 PM
rs kyle's Avatar
rs kyle
Exclamation focus st with fault code C1288 (esp fault) need help
I have a 06 Focus st and the ESP light is on. plugged a fault reader on and it came up with the code C1288. I looked on the internet for the code and found that it is the pressure transducer main primary circuit failed ( not sure what this is). So im wondering has anyone come across this fault before and how do i go about fixing it? (which im hoping to do myself)
Old May 6, 2010 | 08:27 PM
rs kyle's Avatar
rs kyle
up
Old May 6, 2010 | 08:58 PM
iansoutham's Avatar
iansoutham
OCD Victim
Check the connection on the steering column as these have electric power steering.
I would normally expect that code to mean something like the Steering Sensor Circuit has malfunctioned.
If the steering sensor malfunctions, the ESP cannot work out what the steering angle is to allow for compensation when the system is required.
DixieTheKid
Sep 14, 2015 09:04 PM
Si B
Sep 12, 2015 06:49 AM
focus2351
Sep 9, 2015 09:33 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
