Cossie 4x4 vibration round corners
Old May 2, 2010 | 11:00 PM
madfordnut's Avatar
madfordnut
Default Cossie 4x4 vibration round corners
Hi all,
Im hoping someone can help me, i have recently brought a 380Bhp 4x4 Saph cossie, drives spot on in a straight line on and off aceleration however when acelerating around corners/roundabouts i am experiencing a bad vibration through the car and steering wheel, i have put XR4X4 front drive shafts in but still have the same problem??
Any suggestions would be appreciated, thanks for reading this post!
Old May 2, 2010 | 11:18 PM
m4tt274's Avatar
m4tt274
could be leaning over and rubbing on the wheel arches.
could be a wheel bearing going
could be CV bearing, what kinda condition are the driveshafts u put on?
Old May 2, 2010 | 11:24 PM
The Youth.'s Avatar
The Youth.
find out if the previous owner fitted xr4x4 front shafts they are too long and cause exactly this as the tripod joints hits the back of the cup
the other thing to check is the exhaust where it gets close to the front arb chassis, it needs to be right in the middle or it will vibrate on corners mine did on my saph years ago.
steve
Old May 2, 2010 | 11:38 PM
madfordnut's Avatar
madfordnut
steve
i fitted the shafts as i was told they were an upgrade it feels like a inner cv joint worn as it shakes the steering wheel only on acceleration.
Old May 2, 2010 | 11:39 PM
madfordnut's Avatar
madfordnut
Old May 2, 2010 | 11:44 PM
m4tt274's Avatar
m4tt274
yeah i have xr4x4 shafts on mine, they are slightly longer so are ideal for lowerd cars
but mine didnt vibrate.
the only vibration myn have ever had is when the inner arch liner dropped down and was rubbing on corners
Old May 3, 2010 | 06:47 PM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
what is the state of your front tyres? i thought my tracking was out but in the end it was the thread on my tyres. they were worn on the outer edges. since fitting new ones yesterday the car goes beautifully. seems a little thing i know that the lack of tyre thread is the culprit but it could be. mine vibrated at seventy round sharpish corners on dual cariage ways, even worse when on over run.
hope this might help.
Old May 4, 2010 | 12:22 AM
m4tt274's Avatar
m4tt274
radial tyre treads vibrate when they wear down
Old May 4, 2010 | 01:11 AM
ASHCOSSIE's Avatar
ASHCOSSIE
i have simular problem on a 4x4 but only on motorway 70 mph + on right hand bends, feels like warped discs through steering wheel, and when on track i get another o at 100 mph + through te whole car cant even see through rear view mirror cause its shaking so much
Old May 4, 2010 | 09:40 AM
m4tt274's Avatar
m4tt274
that sounds like your prop doughnut has perished
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
gingeRS
Sep 4, 2015 06:29 PM
hopper350
Sep 4, 2015 12:53 AM
cossirob
Sep 3, 2015 09:17 PM
