Hesitation/holding back problem still
Old May 1, 2010 | 05:51 PM
Toe Knee's Avatar
Toe Knee
Default Hesitation/holding back problem still
Right gonna try sort this before it goes to be set up or im gonna have to leave them to fix it.
Basically when pulling away or slow driving when just touching the throttle the car holds back and hesitates and kangaroos till u give it abit more throttle then its fine, even when it comes on boost its fine.
It also has a prob with the ISCV as when its plugged on it'll hold the revs high unless u unplug it and its fine, and had enough now having to wait for it to warm up before its ok to drive and not stall lol. It seems to idle higher too when plugged on when it has warmed up a bit.
I've tried another ISCV and its the same, ive swapped the TPS for another one and it still does it, ive also done a voltage test and resistance test on the TPS and seems ok too!!! The only thing i did find was the butterfly wasnt opening fully at WOT but sorted that and hasnt cured the problem.
Is there anything else that would/could cause this?! coolant or ACT sensor?! Crank sensor is fine and gapped as is the phase sensor.
The only thing that changed from when the chip was fitted was that the head is now ported and the chip was for the head when it was standard, but would that affect the ISCV and cause this hesitation?! Its running rich but been told thats probably due to the porting and changing the chip will sort that, could the map on the chip be causing this problem too?!
Old May 1, 2010 | 05:57 PM
james kiely's Avatar
james kiely
if it were mine ,id change the coolant sensor first,as it has a influence on the fueling ,
eliminate all the simple stuff first toe knee
Old May 1, 2010 | 06:21 PM
It wouldn't hurt to change the cts and ats, then do a emissions check to see if very lean low down, might just need a tweak, if it's very different however will likely need a new chip to suit the head differences.
Old May 1, 2010 | 08:19 PM
cossytonyt's Avatar
cossytonyt
ive had this problem on a couple of cossies first time it was the tps throttle position switch apparently it wears at certain position and once you put your foot down it clears,
second time was on an escos changed every single switch and sensor inc chip and it was a broken wire where the harness comes out of the plug on the big ecu plug,might be worth checking if you have been changing chips etc might just be a pulled wire
Old May 1, 2010 | 10:03 PM
Toe Knee's Avatar
Toe Knee
well the chip was fitted for the previous owner and set up by julain godfreys, there was no mention on their setup sheet about this problem, they had flagged up other issues but that was on the old engine althou this was some 5yrs ago!!
Gonna get them to set it up again just wanted to eliminate as many faults as possible before it goes to them to keep costs down etc!!!
van_dogg_pavvy
Mar 3, 2016 09:30 AM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
