is this an ecu problem??
Old Mar 17, 2004 | 06:41 PM
carl s's Avatar
carl s
Default is this an ecu problem??
my 2wd cossie is only sparking on no1 cylinder, only sending a pulse to no1 injector aswell. anyone had this before?
tried new dizzy cap and arm, any ideas??
cheers
Old Mar 21, 2004 | 09:25 AM
try crank speed sensor and gap should be about 60 thou i think
Old Mar 21, 2004 | 11:15 AM
PJay's Avatar
PJay
As andy says, check the crank position sensor and gap (0.6-0.8mm)and the phase sensor and gap (0.3mm iirc)
Old Mar 22, 2004 | 12:12 PM
Stu @ M Developments's Avatar
PassionFords Creator
Usually Phase sensor issues that create this.
DixieTheKid
11
Jun 6, 2020 11:20 AM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
tib2220
Sep 14, 2015 12:33 PM
dms04
Sep 11, 2015 01:57 PM
