Sierra cossie (BOOST) issue
Old Apr 15, 2010 | 02:52 PM
RS500/364's Avatar
RS500/364
You tried another idel control valve
Old Apr 15, 2010 | 08:13 PM
martysmartie's Avatar
martysmartie
Has the fuel pump been rewired, and when was the filter last changed?
ISCV will have no effect what so ever you could unplug if you wanted to, only time it is utilised is at cold starts where air COMPENSATION is required or when there is a high electrical demand etc.
Martin
Old Apr 15, 2010 | 08:24 PM
james kiely's Avatar
james kiely
fuel pressure regulator maybe?
Old Apr 15, 2010 | 08:37 PM
stickertone's Avatar
stickertone
plugs?????
Old Apr 15, 2010 | 08:47 PM
stickertone
leads maybe???
Old Apr 15, 2010 | 09:09 PM
martysmartie
What are the plug gaps? You need to check the voltage at the pump UNDER load to make sure you are getting correct power, as the old wiring is known for not being up providing the power hence you end up with a lean running engine, does it drive ok apart from at max boost?
Martin
Old Apr 15, 2010 | 09:36 PM
RS500/364's Avatar
RS500/364
But you have the issue with the idel
and can do some strange things but cant remember them atm !
Old Apr 15, 2010 | 09:40 PM
james kiely
as martin said above mate ,you gotta check the voltage at the pump whilst its under load,but i would rewire it anyway to be on the safe side and change the filter again,theirs a good chance that this is your problem
Vincereese
Aug 15, 2015 06:24 PM
RsS2daz
Aug 14, 2015 05:26 AM
Vincereese
Aug 11, 2015 08:44 AM
Red_bull
Aug 9, 2015 08:34 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
