Which RTV sealent to use on CVH sump?
Just about to fit a new sump and have been advised to use an RTV red sealent, anyone used this to good effect and if so which brand did you use as there are so many to choose from
Most likely reffering to Hermatite, get yourself some Loctite gasket sealant from halfords, they do the 5920, the best is 5900, but this is a 5 minute cure time, 5910 is a slower cure time, this stuff(5900/5910/5920) is a thixatropic sealant and is ace, used it years haven't used hylomar since I found this stuff.
mk3ste
17-10-2021 10:09 AM
07-10-2015 12:56 PM
