Pectel T2 Configuration
Old Apr 7, 2010 | 06:47 PM
paulgrs2's Avatar
paulgrs2
Default Pectel T2 Configuration
Having just bought a engine with a pectel T2 ECU I have a ?
Does the Pectel need to run a MAP sensor on a normal aspirated ITB's engine?
If so or if it is best too, then whats the best way to pipe it in (the manifold has no ports, neither has the ITB Titan Roller Barrells) but got some weld on an-6 connectors or m10 to an-6 adaptors.
Thanks alot.
Old Apr 8, 2010 | 07:58 AM
oldford's Avatar
oldford
Most aftermarket ecu's can also be setup for throttle and rpm.
I prefer using a map-sensor. I also prefer a fuel pressure that is corrected for manifold vacuum, so you need a connection anyway.
Old Apr 11, 2010 | 07:43 PM
paulgrs2's Avatar
paulgrs2
is there a set diametre for vac ports?
DixieTheKid
11
Jun 6, 2020 11:20 AM
jessie_rs
62
Aug 6, 2019 09:27 PM
jay030787
Sep 25, 2015 01:38 AM
Steve Cooper
Sep 15, 2015 04:39 PM
muz
Aug 16, 2015 12:57 PM
