500 bhp 3dr fluttering when coming on boost?????
Old 27-03-2010, 06:55 PM
turblower
turblower's Avatar
Default 500 bhp 3dr fluttering when coming on boost?????
wonder if any 1 ever had a problem like this??
when the boost comes the car its like sort of juderiging an u can u see the needle on the boost gauge fluttering whilst going up
i checked a few things on it,it has got air injectors which i unpunnged an it is still doing it an also checked boost pipes,could it be the actuator??
Old 27-03-2010, 07:18 PM
gingerturbo
The annoying ginger guy
gingerturbo's Avatar
its not blowing ya spark out is it
Old 27-03-2010, 07:29 PM
botters
competant bodger
botters's Avatar
sounds like a misfire when coming on boost could be down to a host of different problems that 3dr's are plauged with!
Old 27-03-2010, 07:35 PM
gingerturbo
how much boost r ya running
Old 27-03-2010, 07:50 PM
pee vee
pee vee's Avatar
when you say fluttering? as in chatter?
if so it sounds like surge?
Old 27-03-2010, 08:37 PM
Assume it's previously been mapped ?, and has it come on suddenly or got progressively worse, how old is the fuel filter, has the pump been rewired.
Old 27-03-2010, 08:44 PM
martysmartie
martysmartie's Avatar
As said about pump rewire and filter also what are your plugs/gaps like?
Martin
Old 28-03-2010, 07:49 PM
turblower
turblower's Avatar
it has been mapped by nms an is runing to 2.5 bar,,,the loom has been rewired by motorsport solutions(pectel style)..it just started doing 1 day when i was in 4th an put my foot down,,,is not getting worse or better,its the same...
u can feel the car juddering,
not sure about the fuel filter but im going tochanghe it.......i got 1 of those air an fuel gauge in the car an sometimes runs too lean,,,could that be the problem?u reacon it will need to remapped?
Old 29-03-2010, 01:37 PM
If you can see sometimes runs too lean but other times ok, then this suggests again might be a clogged filter problem, it won't be down to the mapping with karl having done it.
Unless you have chnaged spec since the mapping it won't need remap.
The chips do actually wear out, amazingly it's true but not that quick.
My philosophy is fix what you know is wrong even if you think it is not related as it needs doing anyway, sometimes you get a nice surprise and it fixes other problems.
Old 29-03-2010, 01:51 PM
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
That IS surge. Basically the turbo is supplying more air flow than the engine can consume. Therefore the excess is backing up into the turbo, which is causing the noise you can hear. This is not good and can lead to turbo failure, as the turbo is fighting against itself.
You need the boost curve to be properly mapped to avoid this OR the cams dialling in OR the head properly ported (so it can consumer the amount of airflow given by the turbo at that rpm). I would guess that this is at around 3500-4000rpm and then disappears as the revs rise (as the engine is then working faster and can then consume the air).
You can drive round it by not loading the car in the higher gears (4th and 5th) at this rpm point.
Old 29-03-2010, 05:11 PM
turblower
turblower's Avatar
cheers peeps,,,,yes it does tabetha the actual digital gauge diseapears off as is running really lea lean then all suddenly is running back on stoitch,,,
well ill changhe the fuel filter an if its still doing it its gonna take a trip upto nms......
mgtkr1
107
06-12-2016 04:23 PM
CrOwSoN15
18
22-08-2015 10:24 PM
IAN RS2k
18-08-2015 07:51 PM
RsS2daz
14-08-2015 05:26 AM
Dazts1
Was It You?
02-08-2015 06:44 PM
Quick Reply: 500 bhp 3dr fluttering when coming on boost?????
