startering problem
Old Mar 11, 2010 | 06:22 PM
robgee32's Avatar
robgee32
Default startering problem
hi all
i have recently been experienceing starter problems so i replaced starter and solnoid and battery and ignition switch but still getting a problem
i turn key to start car but nothing happens solnoid on starter doesnt even click all lights come on dash but nothing but some times after about 15-20 times of trying it may start or attept to checked all wires to starter to make sure they are clean and tight but problem is still there
any help welcome
Old Mar 11, 2010 | 06:58 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
check the earth....just a thought
Old Mar 11, 2010 | 07:40 PM
robgee32's Avatar
robgee32
do you meen earth to the starter motor
Old Mar 11, 2010 | 07:51 PM
steve4i's Avatar
steve4i
was you relay nackerd then?
try the earth on the starter motor if your starter aint working properly
Old Mar 11, 2010 | 08:27 PM
robgee32's Avatar
robgee32
you never guess what the problem was
i took long way around but figurd it out took fuse box out and checked everything but box and relays and fuses looked good so i connected it all back up then i thought it might be a break in the live feed to the fuse box so i got some heavy duty positive wire and connected it to fuse box and to battery and bingo lights on dash and everything works but stupid me realized it was the 80amp slow blow fuse that sits near battery so now i have power to everything but starter wont crank it is a new starter and solinoid
A.t.p
Oct 23, 2015 07:54 PM
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
