1994 ford explorer fan problems
Old Mar 9, 2010 | 08:07 PM
thadon13's Avatar
thadon13
Question 1994 ford explorer fan problems
i need to kno how to take tha fan clutch off to get the fan off the water pump so i can replace tha water pump is there any certian way to take it off because im stumped thanx guys
Old Mar 10, 2010 | 12:45 PM
If it's a viscous fan, that is driven from the engine mechanically through the hydraulic clutch on the rear, you need a slim spanner to fit behind the fan, then a hammer to knock the spanner, leave the fan belts etc on, helps to hold it still, if slipping on the belts stuff a rag between belts and the pulley to stop the turning, most are left had thread, so take account of that.
JoeyBoyden
Jan 4, 2024 02:36 PM
markk
Dec 2, 2021 06:59 PM
Zoggon
Aug 10, 2015 10:39 AM
