Heater Matrix
Old Mar 9, 2010 | 08:45 AM
eoeumc's Avatar
eoeumc
It's ALIVE..Well sort of!
Default Heater Matrix
Hi all smart people
Can you please tell me if the matrix from a S1 will fit the S2 ok?
Thank you
Old Mar 9, 2010 | 08:47 AM
OrionRST200bhp's Avatar
OrionRST200bhp
not sure if it will mate, but i have a s2 one in good nick if you need one.
Old Mar 9, 2010 | 10:45 AM
eoeumc's Avatar
eoeumc
I have actually bought one, well its on its way hopefully and the seller said it would but I just wanted to be 100% sure before I started getting the dash out
Out of curiosity, how much you want for it? PM me the details
Old Mar 9, 2010 | 11:23 AM
taz1787's Avatar
taz1787
Escort Cabriolet Owner
yes mk3/4 matrix are the same
Old Mar 9, 2010 | 04:03 PM
eoeumc's Avatar
eoeumc
Thank you very much Taz
Old Mar 11, 2010 | 01:45 PM
eoeumc's Avatar
eoeumc
OK, I now have this in my grasp but was wondering how easy/hard it is to fit it?
My lack of knowledge is out standing, so would it be a job that a novice could do on his own?
Its just that the car is sitting on my drive waiting to be fixed and as I cant afford to get someone to do it atm I thought I might be able to try!
Also, I cant remember if it was on here but I saw a thread with an on-line maintanance guid in it. Any idea as to where it is please?
Thanks peeps
Old Mar 12, 2010 | 09:17 AM
eoeumc's Avatar
eoeumc
No one has any idea then?
Old Mar 12, 2010 | 05:15 PM
Mk1 Mex's Avatar
Mk1 Mex
Series One
Hi,
You dont need to take dash out have recently changed the matrix on my S1.
Check out this thread from seriesoneforum.
http://www.seriesoneturbo.co.uk/showthread.php?t=13891
(you'll have to be a member tho)
I did a step by step guide look at the bottom of the thread.
Hope it helps, If not PM me and i'll give you my mob number and i'll try to talk you thur it.
I'll even try to copy over the thread now for you.
cheeRS
Barney
Old Mar 12, 2010 | 05:17 PM
Mk1 Mex's Avatar
Mk1 Mex
Series One
As per my previous post on this thread i changed my exsisting matrix over the weekend and took a few more pics and thought of a couple of other things that might help.
1) Before even thinking of removing the heater etc i removed the top hose on the matrix as shown.
2) I then removed the bottom hose from the matrix from the thermostat and blew down it to get any water out. Caused a bit of mess but at least it wont go in the cabin now.
3) I then remove BOTH front seats and the whole center consol just to make life easier.
Also to save getting the rear seat dirty, i covered the seat with an old curtain.
4) DRIVERS SIDE, laying on your back looking up you will see this bolt, as mentioned before its a 13mill bolt, i used a longer extension on my rachet to make life easier. Also while i was down there i disconnected all the heater pipes and the control wires.
5) Repeated the process on the PASSENGER SIDE.
6) You'll need a dumpy screwdriver to get on the top screw of the heater matrix.
7) New heater matrix.
Also if your working in your garage or workshop make sure you've get your car far enough out so you dont end up with a flooded workshop like i did.
And i know some of you may have bleed the water system before, but like me if you havent its best to either have a friend give you a hand that does or have them at the end of the phone for advise.
The best advice i can give is to bleed the system from the thermostat where the hose returns back to the header tank, also make sure that this isnt blocked cause mine was and had to soak the header in a very strong mix of limescale cleaner and then use a drill to clean it out.
Hope this sheds a little more light on what needs to be done and doesnt repeat to much on what dubs44 and Simsy has already mention.
OH ONE THING I NEARLY FORGOT THE CLAMPS THAT HOLD THE PIPES TO THE HEATER MATRIX (IF ORIG FORD) ARENT 10MIL THEY ARE 3/8's INSTEAD...
Hope this helps.
cheeRS
Barney
Old Mar 12, 2010 | 10:19 PM
eoeumc's Avatar
eoeumc
Barney, that is a great response to which I am very thankfull of
I will copy and paste this and have a play on Monday
Thanks again
Old Mar 13, 2010 | 11:21 AM
Mk1 Mex's Avatar
Mk1 Mex
Series One
No worries mate..
Have PM'd you..
Chas
Oct 5, 2015 07:13 PM
Flatlinedan
Sep 18, 2015 12:41 PM
