engine not fireing
Old Mar 8, 2010 | 07:00 PM
fixerdude1's Avatar
fixerdude1
Unhappy engine not fireing
Replaced engine as last one blew up so to speak. replaced HT leads and sparkplugs HT lead order 1243. all electrics fine. engine is an 1118/1.1 Fiesta mk3 K reg 1992 model with a carb HCS mechanical engine not fuel injection. Engine turns over but wont fire up can anyone help
Old Mar 8, 2010 | 07:02 PM
sir nose's Avatar
sir nose
spark
fuel
compression
are you sure its 1243 i know some engines are but most are 1342 but it should at least fire if this was the fault.
Old Mar 8, 2010 | 07:04 PM
saph_Al's Avatar
saph_Al
Are u getting a spark ?
Are you getting fuel ?
has it got any sort or imobiliser on it like the chip in the key ?
Old Mar 8, 2010 | 07:05 PM
steve4i's Avatar
steve4i
pull a lead off and see if your getting a spark
Old Mar 8, 2010 | 07:10 PM
fixerdude1's Avatar
fixerdude1
yes the order is 1243 checked re checked. The sparks are fireing the fuel is being supplied. the vehicle doesn't have an imobiliser fitted either still stumped
Last edited by fixerdude1; Mar 8, 2010 at 07:13 PM. Reason: incomplete information.
Old Mar 8, 2010 | 07:29 PM
sir nose's Avatar
sir nose
would it not be single point injectiono on a k plate?
Old Mar 8, 2010 | 07:32 PM
sir nose's Avatar
sir nose
is it trying to fire or just nothing?no pops and bangs
its not fludded is it?
mint_s2
Sep 2, 2015 08:58 AM
RSmark84
20
Aug 24, 2015 02:17 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
ekjim
Aug 17, 2015 08:57 PM
