fiesta mk3 engine not starting
Old Mar 6, 2010 | 11:25 PM
fixerdude1's Avatar
fixerdude1
Default fiesta mk3 engine not starting
replaced engine. fuel pump/HT leads/sparkplugs/ignition coil/electrics ok,all sensors check out fine. Engine turns over, engine tries to start, fuel ignites but still no luck in starting engine. Am thinking of checking compression of pistons but not sure about this action. Any clues or hints pls help
Old Mar 11, 2010 | 07:39 PM
waynefrst235's Avatar
waynefrst235
are all 4 cylinders gettin spark???
if they r i wud get the compression checked mate
Old Mar 12, 2010 | 04:52 PM
steve4i's Avatar
steve4i
or check the firing order is correct or did you change the #HT leads 1 at a time? or just wip them all off?
Old Mar 13, 2010 | 10:50 AM
Don't forget on this engine the firing order is 1/2/4/3 and not 1/3/4/2 as 99.9% of 4 cylinder engines.
JoeyBoyden
Jan 4, 2024 02:36 PM
mk3 fiesta cosworth
Aug 23, 2015 10:31 AM
Aug 20, 2015 09:21 PM
tommylommykins
Ford Fiesta
Aug 8, 2015 08:01 PM
Bosch
Aug 4, 2015 05:14 PM
