Knackered turbo? (with pic)
Old Mar 6, 2010 | 05:33 PM
cabrio zo's Avatar
cabrio zo
From: Sudbury Suffolk, Drives: Octavia VRS & XR2i 1800 Zetec track car
Default Knackered turbo? (with pic)
Not come off of a Ford (Renault 21 turbo) but a turbos a turbo (T3?) car seems to smoke on over run, and when pootling about - white smoke - under load seems to be fine, and will clear if revved for a bit, but if changing down gear to slow for a 30 or traffic plooms a bit.
We took the turbo off, nearly half the oil feed pipe gasket had been covered in sealant so not sure if has had slight oil starvation (this turbo was fitted 6 months ago (second hand I assume)) quite a bit of play in the shaft, looks wet (unlike dry/sooty) and feels oiley, so could it be turbo to blame for smoke?
Old Mar 6, 2010 | 06:14 PM
Knackered turbo, white smoke indicates oil getting in the exhaust side, that's how they do it in the movies pipe oil, normally veg based into the rear box, smokes like del boys reliant!!
Old Mar 7, 2010 | 11:52 AM
cabrio zo's Avatar
cabrio zo
Thanks Tabs, as in exhuast housing I guess the oil could be from the engine - i.e. stem seals gone (it had been over filled with oil)
Old Mar 7, 2010 | 01:12 PM
No I mean exhaust side of the turbo itself, this is shown as the smoke is white, ie it hasn't been burnt, which if it was stem seals would have in the combustion chamber, instead it simply oozes/leaks from inside the turbo, past the ring, which has a gap in it.
Old Mar 7, 2010 | 05:03 PM
cabrio zo's Avatar
cabrio zo
Talk slow and words of one syllabal , I'm female remember
Sorry I meant the pic above is from where it bolts onto the exhaust manifold, I don't know too much of where the oil moved within the turbo apart from where the oil feed pipe is. So stem seals the oil would've burnt in the bores before reaching the turbo, hence white smoke means oil seeping within turbo (just trying to understand)
Oct 9, 2015 07:38 PM
Matt Baxter
Sep 16, 2015 08:30 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
Michael Wisbey
Aug 14, 2015 11:57 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
