escort self ajusting clutch
Old Mar 4, 2010 | 06:20 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
Default escort self ajusting clutch
just brought an 80spec escort and the the clutch is clonking realy badly, i just wanna know how much abuse the rachet on the clutch take,
Old Mar 4, 2010 | 06:23 PM
nellyscossy's Avatar
nellyscossy
you'll know when the ratchet is fooked cause when ya dip the clutch there will be a big bang and ya foot will hit the floor
Old Mar 4, 2010 | 07:57 PM
andy milligan's Avatar
andy milligan
newbe
A weak point in the clutch set up on escorts, can be modded to manual adj and metal quadrant. Another sign of a failing quadrant is that it will click when the padal comes up.
Old Mar 5, 2010 | 05:33 PM
gingerturbo
yeh its doing all that it makes ya jump a bit, how easy is it to moddify cos im not really up for knocking the pin out cos of the brake pedal
Old Mar 5, 2010 | 05:55 PM
JonathanJ's Avatar
JonathanJ
Used to do these in my sleep , it is an easy job on the Escorts , even easier if you remove the drivers seat so you can lie on your back , and pull the ratchet spring off first so it releases the tension on the little red pedal bushes .
Old Mar 5, 2010 | 06:15 PM
AstoN_B's Avatar
AstoN_B
An eye for detail...
Had to do this couple weeks ago on mates mk3.
It wasnt easy, at all, the bar that went through the pedals had swollen on the end with flat machined onto it. Luckily his knocked out with hammer easy enough but was swapping for mine so he could get home again next mornin and mine needed air belt sander on end to make it slip through the hole.
After that its 15 mins to get it back together. Just remember which bushes go where and use correct grease.
Old Mar 5, 2010 | 06:17 PM
AstoN_B's Avatar
AstoN_B
How easy is this to do? Any details?
Wouldn't mind doing this on mine as wont be used as daily so low miles, just dont fancy it breaking after rebuilding the whole car. Looking at the design it looked ok, but mates appeared to be made of cheese so it's likely a replacement will be same.
Old Mar 5, 2010 | 06:39 PM
gingerturbo
oh ok then ill have a go the weekend shouldnt take long
Old Mar 7, 2010 | 07:42 AM
gingerturbo
all done wasnt as har as i thought
Old Mar 8, 2010 | 02:13 AM
gavintwopies's Avatar
gavintwopies
Did you fit the std pedal again or did you put a mk7 one on found fitting a mk7 with the non adjusting ratchet was just the ticket as fitted a helix paddle clutch later
Old Mar 8, 2010 | 06:49 AM
gingerturbo
ooh didnt know that i can do that when i change the clutch
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
cossirob
Sep 3, 2015 09:17 PM
Bighandsuk
Sep 2, 2015 05:23 PM
