ST170 Fuel and temperature Gauges
Old Feb 28, 2010 | 03:40 PM
jack r6's Avatar
jack r6
Default ST170 Fuel and temperature Gauges
Hi,
I have a 2004 ST170, when I turn the ignition off both the fuel and temperature gauge flick very quickly to half way. Both the gauges operate normally when driving the car and the car drives as it should with no fault lights. Just wondering if this is a sign of any possible faults? The oil pressure and temperature gauges operate normally and go to minimum when the ignition is tuned off.
Thanks for any help
Old Feb 28, 2010 | 04:34 PM
martysmartie's Avatar
martysmartie
Common problem on Mk1's, remedy is dash replacement but that is expensive, basically the silicon that keeps the gauges in the min position breaks down and causes the gauges to show half.
Martin
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
IainRS1700T
Sep 25, 2015 06:44 AM
pie-face
Sep 15, 2015 10:43 AM
tib2220
Sep 14, 2015 12:33 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
