How to test abs sensors
Old Feb 27, 2010 | 09:59 PM
whittyscossy's Avatar
whittyscossy
Default How to test abs sensors
Hi what is the best way to test the abs sensors, I know I need 2 use a multimeter on ohms but what 2 do next???
As I belive one off mine is fucked on the front?
Whittyscossy
Old Feb 27, 2010 | 10:00 PM
whittyscossy
What should be the readings I should get?
Old Feb 27, 2010 | 10:04 PM
botters's Avatar
botters
competant bodger
do a search for abs faults in the cosworth section the readings you need are in there
Old Feb 28, 2010 | 12:44 PM
Check them all, as they are not all going to be us, that way one that is substantially different will show up.
Old Feb 28, 2010 | 04:32 PM
whittyscossy
k cheers I was going 2 test them all n e way, wot is the best way to test them I know it's via ohms on a multimeter.
Old Feb 28, 2010 | 04:36 PM
hitchwest's Avatar
hitchwest
unplug each sensor and check the ohmes by touching the probes of your tester on to the 2 terminals in the end of the lead to your sensor which will give you a resistance reading then write it down then go round all 4 you should then see 1 that is miles away from the other readings
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
