saff 4x4 rear inner cv boot
Old Feb 28, 2010 | 10:17 AM
m4rkl's Avatar
m4rkl
Default saff 4x4 rear inner cv boot
mot due this week and need to change an inner cv boot on rear, whats the easiest way?
Old Feb 28, 2010 | 12:39 PM
Unless using a split sticky boot, just unbolt the shaft, take one end off(circlip) easy job, I would get a pair of boots, as sods law the other one will split on the way to mot!!
Old Feb 28, 2010 | 01:10 PM
sir nose's Avatar
sir nose
cv gaiters are'nt a failable item on the rear inner or outer.
Old Feb 28, 2010 | 01:44 PM
m4rkl's Avatar
m4rkl
do i have to take the shaft off? if so what size is the nut on the hub side
Old Feb 28, 2010 | 01:49 PM
Are they not, I didn't know that, bit daft though, was stopped years ago for no lights, as had daylight mot!!
Old Feb 28, 2010 | 01:54 PM
sir nose's Avatar
sir nose
30mm i think
Old Feb 28, 2010 | 01:55 PM
m4rkl's Avatar
m4rkl
bigger than that 36mm is not big enough
Old Feb 28, 2010 | 04:40 PM
darrenr1969's Avatar
darrenr1969
41mm
FlashRS
Sep 14, 2015 12:36 PM
mint_s2
Sep 2, 2015 08:58 AM
YODI
Aug 30, 2015 01:12 PM
borboyous
Aug 22, 2015 11:17 AM
mrmann
Aug 20, 2015 11:24 PM
