fitting a front nsw window on mondeo km3 saloon
if your half decent around cars you will manage... the glass is held in by 2 clamps.loosen the 10mm bolts, clean out the broken glass and slot glass into clamps and tighten bolts..not too tight tho..if you get really stuck give me a shout as i think im just down the road from you
pop the caps off from iside the door handle pull and the grab handle undo the phillips srews . have a look down the edges of the pad and theres a couple down the sides . pull the pad off (it will have clips on aswell so will put up a bit of a fight but not to bad). once removed peel back the door membrain so u can gain acces to the window regulator and runners . CARFULLY clean out the glass from the bottom of the door and rubbers . use a flat screw driver and run it round the rubbers to rmove all the glass. spend a bit of time and make sure u get it all out coz it'll really piss u off when u put the new glass in and i either screeches at u when u put it up or explodes and ur back to square one . as dangerousbrian said the glass is clamped by two 10mm bolts in metal sandwich plates with rubber to protect . once the glass is is in run it up to the top and there should be two access holes where u can see the 10mm bolts nipp them up and check operation of the window . build the door back up . hope this makes sence to you . if u get stuck pm me and i'll see if i can talk u through it . cheers Ally
JoeyBoyden
04-01-2024 02:36 PM
track.focus'd
12-08-2015 05:53 PM
jimmy oldskool
Ford Focus (All Models)
04-08-2015 06:54 PM
