injectors
Old Feb 25, 2010 | 08:27 PM
paulgrs2's Avatar
paulgrs2
Default injectors
Can anyone identify these (as in flowrate, impedence, what fitted to as original) and is there a bosch equivalant.
Thanks in advance
Old Feb 26, 2010 | 09:54 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
http://www.lindertech.com/docs/inj_oem_casting_num.pdf
http://users.erols.com/srweiss/tableifc.htm
this is what i've found for you, ue the first table to see the equvelent numbers for the injectors and then use the second table to find the info.
however info does conflict so not preparred to give an answer, but you could look further into it if you wanted.
hope that helps.
Old Feb 26, 2010 | 10:29 AM
paulgrs2's Avatar
paulgrs2
Thanks mate, will see what I can do with that
mk3ste
Oct 17, 2021 10:09 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
