Heated front window
Old Feb 25, 2010 | 09:46 AM
whittyscossy's Avatar
whittyscossy
Default Heated front window
Hi just a quick Q does any 1 know what amp its ment 2 have I know the back 1 is 30amp can't seem to find it in the book??
Also is it connected to the rear fuse or is it on it's own?? As the book only says about the rear??
Whittyscossy
Old Feb 25, 2010 | 10:40 AM
jon@work's Avatar
jon@work
it doesn't have a fuse, but a fuseible link where it connects to the battery
Old Feb 25, 2010 | 11:29 AM
whittyscossy
K cheers does n e one have a wiring pic?? As the person b4 me has cut it about (driverside is missing and part of pass side terminals) would rather just a make a new 1 up.
Old Feb 25, 2010 | 02:07 PM
Dead simple wiring wise just a live and earth to each side, the relay for the front heated screen is under the dash near the fuel pump relay, ther eis also a seprate timer for the front screen near the relay.
The relay is permanently live from the battery through as said fuseable link, but there is nothing wrong with running a normal fuse on the system, before the relay, close to the battery, 30 amp will do fine.
The relay is only energised when the engine is running, unlike the rear which is just with ignition, my front switch lost it's input power to the switch, so I just jumped across from the rear one.
Old Feb 26, 2010 | 06:46 AM
whittyscossy
Many thanks for info
3dr cossie
11
Dec 21, 2015 03:38 PM
3drRich
Sep 13, 2015 07:32 PM
C2 MAK
Aug 20, 2015 09:46 PM
track.focus'd
Aug 12, 2015 05:53 PM
