wont start!
Old Feb 12, 2010 | 06:17 PM
daladine's Avatar
daladine
Default wont start!
hi there
my 2000 (W) ford focus cut off randomly today and refuses to start, fuel is coming so pump nis fine but just wont start as if there's no spark, any ideas? tried fuel cut off switch btw.
Old Feb 12, 2010 | 06:49 PM
cozzy jeff's Avatar
cozzy jeff
have you checked for a spark?
Old Feb 12, 2010 | 06:57 PM
As above, check for a spark, and don't assume that fuel is coming out of the injectors, it may not be.
Old Feb 13, 2010 | 02:12 PM
daladine's Avatar
daladine
hmm, showing all symptons of crank sensor, do they go often?
Old Feb 13, 2010 | 02:27 PM
Usually when CPS you get no fuelling either not even pump.
Old Feb 13, 2010 | 02:52 PM
daladine's Avatar
daladine
hmm well h hear the fuel pump prime and ct off when pressurised. any other thoughts?
Old Feb 13, 2010 | 05:46 PM
If you're hearing the prime, then it is getting a good CPS signal.
Old Feb 13, 2010 | 05:54 PM
daladine's Avatar
daladine
what else could it be?
Old Feb 13, 2010 | 07:46 PM
Check for a spark, if getting spark, then you narrowed it down a lot as you know it's fuel related, then need in that case to check fo a live at each injector, this live will be constant with ignition on, the earth is pulsed to open the injectors as needed, you really need to establish spark situation first, otherwise you will be going round in circles getting nowhere fast.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
TPM961
Jan 15, 2018 10:50 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
