engine dropped and few other qs...
Old Feb 9, 2010 | 06:00 PM
rsdan2evn's Avatar
rsdan2evn
Default engine dropped and few other qs...
The engine on my fiesta turbo has dropped on the drivers side, what would cause this and more important how do i rectify it? Seems problem after problem at the mo.
I think its called an amel valve but not sure, there is a pipe from the actuator in to it and its plugged into the loom, there is another little pipe coming of it but not going in to anything just the atmosphere is this correct? To describe its black and round, and located on the drivers side.
Also the oil breather is there any were thats meant to plug into or just get a little filter for it? And is there anyway to open it up to clean the inside?
Thanks a lot
Old Feb 9, 2010 | 06:25 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
if its the drivers side its the main mount that ya get to through the wing,
the amal valve should go from the turbo to the actuator
and the oil breather should be a sealed unit so ya cant clean it
Old Feb 9, 2010 | 06:29 PM
rsdan2evn's Avatar
rsdan2evn
so i should have another pipe from the valve to the turbo? were bouts on turbo does it go, only reason i question is because it still boosts fine?
is the wing welded on or bolted?
Old Feb 9, 2010 | 06:33 PM
gingerturbo
if ya jack the car up you should be able to see a 17mm bolt through the wheel arch for the mount, wings welded i wernt ment to put wing lol,
if its boosting fine then the pipe ya can see is probly the breather as the amal valve has 3 nipples on it
Old Feb 9, 2010 | 06:35 PM
martysmartie's Avatar
martysmartie
If the engine has dropped then most likely mounts are shot certainly don't want to be driving it like it, correct it is a Amal valve essentialy electronic boost control. The third pipe goes to airbox if you have one otherwise just vents to atmosphere.
If it's standard breather it goes to a kidney box which can be removed to clean etc on a Cosworth but can't be sure on your car, if it's aftermarket I.E Bailey tip up and empty out some even have a indicator on the side so you can tell. You have two connections on the breather both come from block but can vary, both should connect to breather.
Martin
Old Feb 9, 2010 | 06:46 PM
rsdan2evn's Avatar
rsdan2evn
the valve only has two nips on, sure it goes into turbo or actuator then just vents of. Is it worth get a better catch tank ford one is shite
Old Feb 9, 2010 | 07:55 PM
rsdan2evn's Avatar
rsdan2evn
its looks like this one, one pipe goes to turbo the other vents of to atmosphere
Old Feb 9, 2010 | 08:04 PM
gingerturbo
the only gd thing about the ford ones is if ya got a bit of bottom end back pressure it normalmy pops the ford one, otherwise get a baileys 1, yeh ya right i was thinking of the escort amal valve which is brown with the 3 nipples
Old Feb 9, 2010 | 08:15 PM
rsdan2evn's Avatar
rsdan2evn
i now im asking a lot now lol, put could you post me a link to one please, not hot on rs's
cheers
Old Feb 9, 2010 | 10:01 PM
gingerturbo
http://cgi.ebay.co.uk/ALLOY-OIL-CATC...item439d3c5d2d
Old Feb 9, 2010 | 10:03 PM
gingerturbo
http://cgi.ebay.co.uk/Bailey-Alloy-O...item3caa058aae
gingerturbo
there ya go see if they help ya out
Old Feb 24, 2010 | 06:02 PM
rsdan2evn's Avatar
rsdan2evn
Just to update sorted this, the screw that went in to mount droped because the bolt was missing, all sorted correctly now.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Bailes1992
Sep 3, 2015 02:17 PM
Bailes1992
Aug 16, 2015 07:14 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
lockie
Jul 31, 2015 10:03 PM
