escort gti
Old Jan 31, 2010 | 08:01 PM
stevescort1's Avatar
stevescort1
Default escort gti
hi is it normal for water to spit out exhaust jus noticed could it be due to it idleing a bit jumpy
Old Feb 1, 2010 | 12:32 AM
keyz's Avatar
keyz
Arse
ALmsot all cars have water coming out the exhasut.. especially people who only drive short distances.. Youll find it alot on peoples car who do shorts trips to school or the shops etc...
Providing its not chucking out steam ( head gasket failure usally ) then your all good
as for your lumpy idle, u might need your ICV ( idle control valve ) cleaning.. ( under air intake ) or you might have an air leak for it to idle rough
Old Feb 1, 2010 | 07:06 PM
I don't know where the "almost" comes from any fossile fuel burning engine will produce water H2O, as this is naturally present in the air the engine consumes.
It looks a lot wworse due to the time of the year being cold, there being a much bigger temp difference between the exhaust gasses coming out and the cold air causing it to condense again, in the summer this evaporates so is not seen that's all, still there though, once run a while and the whole exhaust system up to temp it will be a lot less, even seeing drips of water or streams as you pull away after diling a while is nothing to worry about with a cold engine, and does not show HG gone.
Dr. Ickxs
Sep 15, 2015 10:15 PM
rogerxr3i
Sep 13, 2015 06:56 PM
bassboy
Sep 10, 2015 08:54 PM
imnoteasy
Sep 7, 2015 09:26 PM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
