Autronic/electrical gurus,..
Old Jan 31, 2010 | 08:56 PM
Rabbit's Avatar
Rabbit
Default Autronic/electrical gurus,..
On the loom supplied with the SM4 there are one relay to control the injectors and the fuelpump. On a sierra cossie with standard fuelpump, is this sufficient? or will i fry the relay/blow the 30A fuse?
User manual says that the SM4 draws max 16A, less depending on injector type.
Old Jan 31, 2010 | 09:05 PM
Its Dave's Avatar
Its Dave
Drop Mark Shead or Mad Rod a pm they will help you
Old Feb 1, 2010 | 07:09 PM
Not sure on the std pump, but the 044 locks out at 18 amps, so really needs another relay, as it's very close, easy just do a pump rewire/relay at rear and helps your car as well!!
RSmark84
Sep 13, 2015 01:29 PM
kitch29
Jun 16, 2015 12:34 PM
Martboy21
Fiesta RS1800/RS Turbo
May 3, 2011 05:54 PM
MikeR
Jul 15, 2008 08:12 PM
Porkie
38
Nov 2, 2007 11:22 PM
