Mk3 fiesta power steering.
Old Jan 27, 2010 | 05:59 AM
Lewis-_-92's Avatar
Lewis-_-92
Default Mk3 fiesta power steering.
I want To put power steering on my fiesta 1.1 what do i need and how much will i be looking at spending?
or if you know a cheaper way to make steering better please let me know
Old Jan 27, 2010 | 05:53 PM
Different tyres can make a huge difference.
If there is any version of the mk 3 festa with PS simply rob all the bits from that, mainly rack pump hoses, reservoir.
Old Jan 27, 2010 | 09:11 PM
Lewis-_-92's Avatar
Lewis-_-92
ye i was thinking that, the fiesta SI has P.S and other parts i could rob off it, guess ill be going to the scrappy tomorrow.
Old Jan 27, 2010 | 09:17 PM
AndyST's Avatar
AndyST
Do you really need PAS on a 1.1 Fiesta? If you feel it's too heavy there may well be a problem, check tyre pressures and also the steering knuckle where the column meets the rack can sieze and cause heavy steering, when all components are good, the steering is easily light enough.
Old Jan 27, 2010 | 09:19 PM
Lewis-_-92's Avatar
Lewis-_-92
ye well as i only just started driving and iv got 0 no claims i want to keep the car as long as i can till i can get a RS so i want to make it a comfy ride. my dad did say sumin bout a quick rack?
Old Jan 27, 2010 | 09:39 PM
saph_Al's Avatar
saph_Al
A quick rack will make your steerin even heveier buddy , if you really want pas then you gonna need
Rack
Pump
Pump bkt
Pipework and clips
auxbelt
Res and pipe work
and about 2liters of pas fluid
and all the bolts and nuts .
And what ever else ive forgotten
Cheers Ally
Old Jan 29, 2010 | 12:05 PM
If you use a different steering wheel it will be much lighter, one from a double decker bus will give lots more leverage!!
155lee
Sep 6, 2016 11:10 AM
Dr. Ickxs
Sep 15, 2015 10:15 PM
fordfiestamk3
Sep 11, 2015 12:52 PM
Brian
Sep 11, 2015 08:06 AM
Bighandsuk
Sep 2, 2015 05:23 PM
