Immobiliser Fault ???
Old Jan 24, 2010 | 03:47 PM
misiokicio's Avatar
misiokicio
Default Immobiliser Fault ???
Hi All
I am new on this forum and also never had a ford before
I have a Mondeo 2001 1.8 in petrol so is MK3
The car has been fine two days ago(driven for about 150 miles)
And today morning i cannot start the engine.
I check the light and is illuminating for 3 seconds and going off so seems like the IMO is working fine. Engine is turning but no chance to start it. New battery has been fitted as well but no results
What can be the cause??
Old Jan 24, 2010 | 04:28 PM
martysmartie's Avatar
martysmartie
Correct if the light has gone out that should mean the immobiliser is disengaged. If it was me I would do a simple check next seeing if you have spark and fuel being delivered. Does the fuel pump prime when ignition is switched on?
Martin
Old Jan 24, 2010 | 04:35 PM
misiokicio's Avatar
misiokicio
there is a spark but there is no fuel being delivered at all! Dry plugs.
I can't hear the pump either
Old Jan 24, 2010 | 04:43 PM
martysmartie
Check the "Inertia switch" for the pump think it's in the drivers foot well on your car. This could have activated and cut the supply.
Martin
Old Jan 24, 2010 | 04:53 PM
misiokicio's Avatar
misiokicio
thanks for reply. I will try to locate this switch. What i need to do to locate it? lift the carpet under pedals?
thanks
Martin
Old Jan 24, 2010 | 05:13 PM
martysmartie
No, nothing like that it's designed to be accessiable, it should activate on impact but not always, so to cut the fuel supply for safety. I think it's around the drivers kick trim area on your car.
From memory on the kick trim there is a gap at the top it may be in there.
Failing that your handbook will tell you where it is.
Martin
Old Jan 24, 2010 | 05:16 PM
misiokicio's Avatar
misiokicio
I found it! But red button is inside so i am think is ok. Is not pushed out. I am freaking out now cos there is one guy who checking the car but seems like he have no clue what is doing lol. Maybe ford dealer would be the best option but pricey
Old Jan 24, 2010 | 05:23 PM
martysmartie
The fuel pump should prime when ignition is switched on as signalled by the CPS, the fact it isn't is why it's not starting, have you checked power to the pump/tried a direct feed to pump as this will show whether pump is good?
Martin
Old Jan 24, 2010 | 05:25 PM
misiokicio's Avatar
misiokicio
will wait now and have a look tomorrow. thanks for your help mate. will be in touch tomorrow
tankybaby66
Feb 6, 2016 02:24 PM
Flatlinedan
Sep 18, 2015 12:41 PM
DixieTheKid
Sep 14, 2015 09:04 PM
NC53
Sep 13, 2015 03:05 PM
