another fuel pipe Q
Old Jan 24, 2010 | 04:45 PM
sir nose's Avatar
sir nose
Default another fuel pipe Q
ive searched this site alot for answers about fuel pipes for cosworths but i cant find the answer to my question.
i have to replace the underbody fuel pipes due to them being crushed,i was going to use knuifer 5/16 pipe but i cant see how to get the original connecting clip off,the black/red clip that joins the metal fuel pipe to the plastic fuel pipe without breaking the clip.once ive got the new kunifer pipes on the car can i just throw away the old plastic pipe and use rubber fuel injection pipe to the rail etc?
Old Jan 24, 2010 | 06:59 PM
Yes easiest way is to break off and use new fuel injection pipe to do the ends, the original joints are sweated on with a mini heater machine that simply clips over pipe and takes a split second to heat enough to shrink to shape.
I use 8mm OPA from Walker Rubber and Plastic, also do silicone pipes!!, about £1 a foot, is okay up to 25 bar, well over twice the pumps max so no problem, resistant to Oil Petrol Air hence it's name.
155lee
Sep 6, 2016 11:10 AM
steve.rst
Mar 15, 2016 08:01 AM
155lee
Oct 27, 2015 04:55 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
