Explorer 4.0
Old Jan 19, 2010 | 11:05 AM
Thood's Avatar
Thood
Default Explorer 4.0
Hopefully someone can help. I have been given a 1998 Ford Explorer, however it is a nightmare to start from cold, it will rev up to 3000 rpm and then drop down and cut out. you can contol it, just about, with the throttle but you can't put it in gear until it stabilises. The MAF is fine and the air inlet gaskits have been checked are seem ok. This is my last chance. Any ideas ??
Old Jan 19, 2010 | 11:55 AM
Quite a few things it could be, check the CTS resistance, and the emissions.
Old Jan 19, 2010 | 12:02 PM
Thood's Avatar
Thood
Hi Tabetha,
I'm not very technically minded, what is the CTS and how would the emissions cause the problem. Sorry if I appear a bit stupid.
Old Jan 19, 2010 | 04:04 PM
Hi,
No probs matey, you are hardly stupid, you are intelligent enough to ask when you don't know!!
The CTS is coolant temperature sensor, this senses the water temperature and sends this info to the ecu, electronic control unit, the box of electrickery that controls the fuelling and ignition on your vehicle.
This is the one item that has more bearing on the mixture than anything else, the mixture means the ratio or air to fuel, commonly expressed as AFR, air/fuel/ratio.
When the engine is cold(cold water) it needs a richer mixture(like a choke does) so it has more fuel added to the same amount of air to keep running nice, obviously if the CTS is misreading it doesn't know where it is.
A normal culprit for idle problems is the iscv, idle speed control valve, but the fact it raises to 3000rpm shows this to be working IF you are 100% certain it has no air leaks.
The engine needs air to run and with the throttle closed this is supplied through the iscv, OR any air leak, also any air leak if on a "maf" system is not accounted for, not known by the ecu so it doesn't account for it, and the mixture becomes weaker than it needs to be.
This is all measured once burnt in the engine by the lambda, this simply measures the amount of oxygen present in the exhaust gas which is directly proportional to the mixture, sends this info to the ecu, which then makes adjustements as necessary, this happens many many times a second.
Just take to local mot centre and ask them to do a gas reading on it.
Old Jan 20, 2010 | 09:22 AM
Thood's Avatar
Thood
Hi,
Hi again,
Blimey, you know your stuff!!!!
I'll get the car tested today at an MOT centre and get back to you.
Many thanks again for all your advice
Mark
Old Jan 25, 2010 | 07:02 AM
Thood's Avatar
Thood
Hi,
Hi,
I have checked the MAF again and it's fine, I have cleaned the iscv and it's fine, I have cleaned out the air inlet system, this was pretty clogged up but is now clean.
Still not solved the problem, I had the emissions checked, the Lambda was spot on when the car was revved but out when idling.
I asume this means that there is not an air leak on the system, so would I be right in thinking that perhaps the ecu could be failing?
DAN@ADRIAN FLUX
37
Sep 20, 2015 10:38 AM
davey170
May 29, 2005 09:37 PM
GrimmeRS2K
May 15, 2005 10:03 PM
XRT_si
May 5, 2005 06:26 PM
Rene
Technical essay Archives
101
Apr 7, 2004 03:34 PM
