Technical essay Archives A collection of topics you really shouldnt have missed first time round if your interested in the technical aspect of how these Fords work..!! Also many Workshop manuals available in downloadable format. Access is available to Gold Members only.
Mappers ... serious question trying to understand bhp per...
Old Nov 3, 2003 | 12:30 PM
Rene's Avatar
Rene
Default Mappers ... serious question trying to understand bhp per...
Ok guys i am trying to understand this thing (bhp per injector)
we have 1.5 bar of boost
we have 4.0 bar fuel press on idle
4.0 bar on greens = 493 cc/min
so on WOT (Wide Open Throttle) you have(need) 4.0 + 1.5 = 5.5 bar fuel press
5.5 bar of fuel press on greens = 390 cc/min (2.5 bar) + 427 cc/min(3.0 bar) (given by matts figures)
= 817 cc/min
now convert cc/min to lbs/hr
817 / 10.5 = 77.80 lbs/hr
now i want to calculate the bhp per injector
inj. size (lbs/hr) * 0.8 (80% ducty cycle) / 0.6 (.60 lbs (turbo charged)) = bhp per injector
77.80 * .8 / .6 = 103.73 per injector
all 4 injectors 103.73 * 4 = 414.92 bhp
now is this correct? (i think not but where did i fooked up?)
and is there a way how you can calculate which plug gap u need?
thanks!
Old Nov 3, 2003 | 12:37 PM
Stu @ M Developments's Avatar
PassionFords Creator
Rene,
Fuel pressure...
Old Nov 3, 2003 | 12:38 PM
Rene's Avatar
Rene
could u correct the point where i went wrong ? (just that part not the whole lot)
Old Nov 3, 2003 | 12:40 PM
Guinnless's Avatar
Guinnless
Originally Posted by Stu @ M Developments
Rene,
Fuel pressure...
Beat me too it
You will always only have 4.0 bar fuel pressure. I'll tell ya seeing as Stu won't
Old Nov 3, 2003 | 12:42 PM
Rene's Avatar
Rene
you mean the fuel press you set on idle wont get any higher then that?
Old Nov 3, 2003 | 12:43 PM
PJay's Avatar
PJay
Are the cossie fuel press reg's not riseing rate?
PJay
Rene's Avatar
Rene
PJay
my question exactly
4 bar ABSOLUTE pressure
pluggap depends on boost, plugs, coil etc.
oh, and haircolor
Come and pick up that radiator and give me back my cd's...
Old Nov 3, 2003 | 12:45 PM
Rene's Avatar
Rene
oh, and haircolor
1st thing i thought wen i saw that u replied was OHOH
u got the rad then ?
will soon come up your way then we can have a nice chat
btw any figures so i could calculate the plug gap?
Old Nov 3, 2003 | 12:51 PM
Rene's Avatar
Rene
oh and how does it works if you havent set it up on absolute pressure ?
does above apply then ?
Old Nov 3, 2003 | 12:54 PM
Well you should set it up at absolute pressure i.e. sans vacuum...
You don't calculate the plug gap as far as I know: you just ask a tuner and go by that! At a guess I'd say 0.6 will do nicely!
Guinnless's Avatar
Guinnless
The fuel pressure at the injector tip 5.5 bar but you have 1.5 bar in the inlet manifold. So you have an actual 4.0 bar.
HTH
Old Nov 3, 2003 | 12:57 PM
Rene's Avatar
Rene
thanks hooligan and guinnless for explaining that so it should always be setup on ABSOLUTE press (not that i was doing otherwise i do what ive been told to do just want to understand it )
thanks!
Old Nov 3, 2003 | 01:03 PM
Guinnless's Avatar
Guinnless
Glad to help
Old Nov 3, 2003 | 01:11 PM
Wahay stevie..
I reckon that answer puts you in the most knowledgable 3% of users on here...
I know for a FACT that most tuners in the uk dont know that M8, hence i thought id wait around and see who said what
Oh well.. You blew that plan to fook
Old Nov 3, 2003 | 01:13 PM
Rene's Avatar
Rene
just did a calculation on 4 bar absolute but the max i can get out of it is 250.4 bhp
still don't get it
Old Nov 3, 2003 | 01:17 PM
Guinnless's Avatar
Guinnless
Wahay stevie..
Thanks Stu
Old Nov 3, 2003 | 01:24 PM
Karl's Avatar
Karl
Norris Motorsport
Yes as Stu rightly pointed out its amazing that many folk dont realise why we use a rising rate fuel pressure regulator!
Put simply any liguid or gas will always flow from a region of high pressure to a region of lower pressure until the pressure is equalised.
If we set our fuel pressure to 4bar at atmosperic pressure then we have an effective 3 bar fuel pressure above atmospheric. For every 1 bar boost we add, we must increase the fuel pressure by the same amount in order to keep the 3 bar differential pressure.
Failure to do this will result in a diminishing injector flow rate as we increase boost!
Old Nov 3, 2003 | 01:35 PM
84 views... at least 70 of em resulted in a loud "Ehhh? " i reckon..
Rene's Avatar
Rene
so acutally my story in my start post works just isnt for setting up as absolute pressure
Old Nov 3, 2003 | 01:36 PM
Rene's Avatar
Rene
think so but i would like to understand
Old Nov 3, 2003 | 01:38 PM
It's actually pretty logical I'd say...
Old Nov 3, 2003 | 01:41 PM
Rene's Avatar
Rene
hooligan then why doesnt my calculation works?
i used 4 bar fp and the best i can get out of it on all 4 injectors ie 250.4 bhp
Old Nov 3, 2003 | 01:42 PM
PhilM's Avatar
PhilM
PassionBMW.com Member
Another wickid passionford post
Rene's Avatar
Rene
aye now understand, i must
Old Nov 3, 2003 | 01:57 PM
Rene's Avatar
Rene
please someone explain in plain proper english cause i am foreign i am getting headaches
why does my calculation on 4 bar dont work ?
Old Nov 3, 2003 | 02:02 PM
Mr Bump's Avatar
Mr Bump
Puts hand up
Is good info tho
Ben
Old Nov 3, 2003 | 02:06 PM
Rene's Avatar
Rene
ok i got this stuff in my calculation you do a x 0.8 (80% duty cycle) then the end result = 250.4 bhp on all four injectors
100% duty cycle = 313 bhp
guess that's it then ?
Old Nov 3, 2003 | 02:17 PM
Try it with a BSFC of 0.75 mate
Old Nov 3, 2003 | 02:25 PM
CraigN's Avatar
CraigN
:blonde: dime bar
i read this try to understand and then my mind shuts down and tells me to play minesweeper
Old Nov 3, 2003 | 02:32 PM
Rene's Avatar
Rene
thanks stu
but i think ill see if hooligan can explain it to me in dutch
cause with a BSFC of 0.75 i would need to flow 620 cc/min to get a 315 bhp (is that correct?)
Old Nov 3, 2003 | 02:38 PM
Smit's Avatar
Smit
The 60ft Launch King
well thats me lost
Old Nov 3, 2003 | 02:47 PM
R4N SS's Avatar
R4N SS
"Ehhh? " i reckon..
Old Nov 3, 2003 | 02:49 PM
The point being, a small adjustment of the BSFC figure results in a large eror in injector choice..
How do you know the BSFC of the YB?
Old Nov 3, 2003 | 03:00 PM
Don't bother understanding Rene: pay Stu or Tony to understand and use your time to better effect i.e. learn how to fuckin drive properly to save me having to wait on you after every corner on the ring next year!
Old Nov 3, 2003 | 03:09 PM
Rene's Avatar
Rene
it is the measured fuel flow in pounds per hour divided by the horsepower.
Old Nov 3, 2003 | 03:11 PM
Rene's Avatar
Rene
just need to get mine setup still running just about 1 bar ill try not to blow up me engine this time
where can i get a decent FP gauge hooligan like marijns's one? cause i am fed of telling that not having any time to setup me car
Old Nov 3, 2003 | 03:38 PM
Drop by and I'll do it for you...
By: How do you know the BSFC of the YB? STU means SPECIFIC for the YB-engine I think...
Old Nov 3, 2003 | 03:40 PM
Rene's Avatar
Rene
cool happen to have a welder by any chance ? i've got a lambda sensor wich still needs to be fitted
thought that what i replied was a std rule ?
Old Nov 3, 2003 | 03:48 PM
Yes but I imagine it differs per engine you plank!
Got a welder, need a downpipe and the boss for the sender to fit it...
