What Cams??
Old Jan 18, 2010 | 05:47 PM
JamesyRS's Avatar
JamesyRS
Default What Cams??
Hi guys,
How would I find out what cams are in my zetec engine? I bought the car with these in and havent had contact of what ones they are all I know is they are kent cams and need to know for my rolling road to tune n adjust them for settings. If I took rocker cover off would the code be stamped on the camshaft its self? Any help would be much appreciated ave got a couple of weeks to sort it out for mot
Old Jan 19, 2010 | 12:11 PM
Kent are stamped on the end of the cam, so can dial it in when you look up the settings, if going for rr tune though fit some verniers for best effect, so they can do a cam swing.
Old Jan 19, 2010 | 04:34 PM
JamesyRS's Avatar
JamesyRS
hi again tabetha, where about exactly are the stamped? Its already got the vernier pulleys on the guy asked when a phoned up mentioned that he would tune it for power so that the cams werent being a waste of time thanks again for your help you really know ur stuff
Old Jan 19, 2010 | 05:25 PM
JamesyRS's Avatar
JamesyRS
also meant to say tht the tickin over problem cudnt be down to ecu cud it? as its a 1.8 but still on the 1.6 ecu?
Old Jan 19, 2010 | 06:08 PM
If the tuner is able to map the ecu you have don't worry about which ecu you have it will be adjusted as necessary.
The marking is normally on the other end to the pulley, so cover off and a little mirror should sort it to see the markings.
Old Jan 20, 2010 | 07:29 PM
JamesyRS's Avatar
JamesyRS
want to give you a big thanks tabetha finally gona get sumwhere with the runnin of ma mk3 managed to get cam code and settings for rolling road well chuft CHEERS
Old Jan 21, 2010 | 06:22 PM
No probs matey, glad it was useful.
I'm going to the Snetterton track day in the morning, missed the last one, to watch someones car get a pasting, both running emerlad k3, but ones cheating, saxo boys eh!!
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
