low mpg on 2001 mondeo
Old Jan 10, 2010 | 12:00 PM
bigtel's Avatar
bigtel
Default low mpg on 2001 mondeo
i have just bought an x reg mondeo 2.0L tddi facelift version i put £30 OF diesel ini t and i only got 130 miles from it i understand that the snow will be effecting it as i live on a hill and have to put my foot down to get up hill, does anyone know what mpg i should really expect to get?
thanks
Old Jan 10, 2010 | 12:13 PM
TOMMY_RS's Avatar
TOMMY_RS
SHITE!
about the same as your getting lol?
i only get 90 mile from my bike and that costs £10 to fill
Old Jan 10, 2010 | 06:38 PM
I would imagine substantially more than that, I'd be wanting at least 200 unless it is thrashed to death and knackered.
Old Jan 11, 2010 | 12:34 AM
bigtel's Avatar
bigtel
it on an x plate with 92k on the clock might get it serviced see if this helps someone said to try and clean the egr valve but ain't a clue how to do it. thanks for the reply tabetha.
Old Jan 11, 2010 | 02:11 AM
Fiddy's Avatar
Fiddy
Mate i can get that kind of mileage out my V6 if i go steady, you should be getting a lot more than that. the diesels can suffer injector problems, and the injectors need remapping, dont know if that causes bad mpg, though. what does it run like ?
Old Jan 11, 2010 | 04:06 PM
The egr valve won't cause consumption like this, I would be looking for a leak first, unless you have a dicky reading milometer ?, check the basic stuff ie brakes not binding, tyre pressures.
Old Jan 11, 2010 | 09:45 PM
bigtel's Avatar
bigtel
hi guys the car seems quite sluggish but as i have never drove one before not sure if it just a heavy car, i will check tyre pressures but i am crap when it comes to checking most other things, it drives ok to me but again could just be cos i ain't driven one before. i have also got a meriva which i drove tonight for the first time in a week and it was like a rocket compared to the mondeo. is the injector thing easy to check or is it a garage job? the tyres do need a little air in will try this when i get it back from mot test tmw. thanks for the replies really appreciate it.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
timsrs
Nov 13, 2018 11:48 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
Tank Mike
Sep 26, 2015 08:07 AM
