Help Needed: MK 5 fiesta zetec s throttle body vacuum pipes
hi guys im new to the forum and ive found myself in a bit of trouble and was hoping that i might find some help here, so here goes my first post
im building (well nearly completed) a puma 1.7 zetec engine conversion into the fiesta, im using the fiesta zetec s throttle body but cant recall where the two pipes on the throttle body go to. I have one going to the FPR, but no idea about the other one! i have so many pipes lying about in my garage and i just dont know which is the right one or where it leads to! I have been searching on the internet for hours on end trying to find pictures of the throttle body connections or any information that will tell me but i have had no luck at all
if any of you guys have any information regarding this it would be greatly appreciated
cheers
cheers
Measure the vacuum at idle, and see what it is, soon tell you if it has a leak, don't forget the pcv valve can stick open, just clamp pipe with pliers to see if it has, should be shut at idle, but if open will cause havoc.
hello mate i am looking at doing the same conversion my self as i have both the puma and fiesta all intact so i will have a look sometime this week if that of any help to you if you pm me a number then i should be able to text a pic or two
