2wd cosworth gearbox issues!!!
Old Jan 1, 2010 | 09:55 AM
Rollin Rides's Avatar
Rollin Rides
Anyting forsale let me no
Exclamation 2wd cosworth gearbox issues!!!
Changed my gearbox oil last night and now it seems hard to get into 3rd gear? Before this it was fine. I used atf fulid as that's what's it recomended. Any one !!!!!
Old Jan 1, 2010 | 10:03 AM
4x4 S2 Cossie's Avatar
4x4 S2 Cossie
Sounds worn?? The syncros wear - classic T5 trick. How long have you had it? The previous oil could have been a heavier grade gear oil that might have helped the gearbox along, hence when you put the ATF in the problem arose? Would prob be worth changing to gear oil anyway - 75W90??
CheeRS, Chris
Old Jan 1, 2010 | 10:09 AM
Rollin Rides
I have had it 4years and only just got it bk out on the road, the gearbox was fine before and it was red oil that came out!!!!
Old Jan 1, 2010 | 10:22 AM
4x4 S2 Cossie
Interesting?
Does it ease after a while when things have warmed up?
CheeRS, Chris
Old Jan 1, 2010 | 10:27 AM
Rollin Rides
It eases after a couple of changes. It's only really the first couple of times, you can also feel each gear more now than before!!!!!
Old Jan 1, 2010 | 10:28 AM
Alvyn's Avatar
Alvyn
IF the gearbox was fine before and ONLY now after being sat up for a long period of time is difficult to select it WILL take a few miles for it to become fully lub'd up m8! and I ONLY use ATF fluid m8!
Old Jan 1, 2010 | 10:42 AM
Rollin Rides
Sorry misunderstanding I have been using it for the last 2months no probs. Changed the oil as I throught it would be good idea and now the probs!!!!!
Old Jan 1, 2010 | 10:49 AM
Alvyn's Avatar
Alvyn
what atf did you use?? Dexron 2 is what I use
Old Jan 1, 2010 | 10:57 AM
4x4 S2 Cossie
If the previous oil was in for a reasonable period of time, it would have thickened up over time. By putting in the new thinner oil, it could have identified the wearing of syncros that was previously disguished?
Sorry, know it doesn't give you a decent answer - just throwing ideas around.
CheeRS, Chris
Old Jan 1, 2010 | 11:10 AM
Rollin Rides
Yeah mate it's dexron 2, wish I never changed it now lol.
Oct 9, 2015 07:38 PM
Chas
Sep 21, 2015 08:57 PM
Aug 14, 2015 07:29 AM
RIB1122
Aug 3, 2015 09:20 AM
Old ford
Jul 31, 2015 06:50 AM
