escort derv heater prob
Old Dec 27, 2009 | 06:47 PM
lockstock169's Avatar
lockstock169
Default escort derv heater prob
righty ho .. here goes 1999 escort 1.8 td ,, takes a long while to heat up ,once hot heater ok for 30ash miles then starts to blow cold check water in header its ok ,, undo water bleed tap {on thermostst pipe} let water replace airthen top up with bout2 pints of water no signs on any pipe or joint or signs of hesd gasket gone,,, any ideas anyone
ps there are 2 HARD PLASTIC GROMITS with small holes in are these supposed to be there ??????????????/
Old Dec 27, 2009 | 07:51 PM
Alvyn's Avatar
Alvyn
try changing the state m8!
Old Dec 27, 2009 | 08:58 PM
cozzy jeff's Avatar
cozzy jeff
funny theres alot more questions about diesels since the weather got colder,as above
check the stat first.
Old Dec 27, 2009 | 09:13 PM
lockstock169
will do,,,,,,,,, but what do you recon to plastic widgets in pipes
Old Dec 27, 2009 | 09:58 PM
saph_Al's Avatar
saph_Al
if u could get some pics of these gromits it would help . but as above check that its got a stat and it works
Old Dec 27, 2009 | 10:20 PM
lockstock169
Will try but there bout 1.5" down hoses
Old Dec 27, 2009 | 10:23 PM
saph_Al's Avatar
saph_Al
If thee that far down and both look the same chances are there suppose to be there. Might be somthin to do with slowing down the water flow for the best level of heat conduction
Old Dec 27, 2009 | 10:37 PM
lockstock169
many thanks
Old Dec 28, 2009 | 02:12 PM
cozzy jeff's Avatar
cozzy jeff
is this what your looking for
Old Dec 28, 2009 | 03:21 PM
lockstock169
no got that these are plastic bungs with small holes throuhg then ,,,,,
flow restrictors?
Dr. Ickxs
Sep 15, 2015 10:15 PM
gcfcos
88
Sep 15, 2015 03:48 PM
bassboy
Sep 10, 2015 08:54 PM
imnoteasy
Sep 7, 2015 09:26 PM
