where/how to fit fuel pressure sender saph 4wd?
so i want to fit a fuel pressure gauge to my 90' saph cossie,i guess it has to go between regulator and the rail,but how?is there a kit available?
The easiest way is to weld/silver solder a 1/8 NPT connection on the rail itself, if you get stuck getting this done I can get it done no probs, actually I might even have a 4wd rail already done, I'll have a look tuesday, and let you know.
Although you can buy as mentioned regs with gauges, some are of a dubious quality.
sir nose, I have taps dies for 1/8 NPT, plus all the others so can always knock you up a fitting of your own to get put on.
I also have access to a brand new 3 axis CNC mill machine, which can do just about anything!!
Stu @ M Developments
41
21-08-2015 06:47 AM
Zoggon
10-08-2015 10:39 AM
lockie
31-07-2015 10:03 PM
