RallyKa help please...considering a Zetec.
Old Dec 14, 2009 | 10:27 PM
RedLexus's Avatar
RedLexus
Default RallyKa help please...considering a Zetec.
Hi all , I've been offered a 1400 Zetec out of a Puma as an upgrade for the Endura in my Rally KA , which is currently about 95bhp . The complete running gear , absolutely everything bar the bare shell and steering column is mine for a couple of hundred quid .
Is the 1400 basically the same shape and design as the 1800/2000? Same types of mounts etc?
Just trying to figure out how to mount it . Also does anyone know if my (KA) gearbox will bolt on , as it's been uprated and fitted with an LSD .
The class limit is 1450 cc , no forced induction.
Thanks.
Old Dec 15, 2009 | 04:59 PM
James998's Avatar
James998
1.25/1.4/1.6 Zetec SE's are compeltely different to 1.8 and 2.0 zetecs, if you wanted an 'off the shelf' option, you can buy mounts and stuff from trackdesigns., i believe your gearbox will fit but you may need to swap the bellhousing over.
Old Dec 15, 2009 | 05:04 PM
RedLexus's Avatar
RedLexus
Thanks for the reply .
I have seen the TrackDesigns kit... but I would like to make my own mounts if possible .
Old Dec 15, 2009 | 06:39 PM
Dan track ka's Avatar
Dan track ka
Not sure bout the gearbox pal, but if you need a different box ill buy your IB5 from you. Need one for my ZVH conv.
Ex-Finesse
15
Mar 10, 2009 04:11 PM
tocca
Jan 3, 2007 07:04 PM
focus three door
Dec 18, 2006 08:06 AM
s34ton
Ford Focus RS
Dec 19, 2005 09:51 PM
fo0q
Dec 2, 2004 04:49 PM
