1600 cvh engine bores advice please
Old Dec 12, 2009 | 01:10 PM
bigjono's Avatar
bigjono
Default 1600 cvh engine bores advice please
im building a 1600 cvh engine out of h-reg orion 50k genuine miles(i knew the lad and he had it from new)for hot fords,
the pistons have loads of slap/play, so ive ordered 4 BRAND new pistons and rings off ebay £30 plus £7 post BARGAIN
THE PISTONS ARE 0.03MM OVERSIZE could i get away with honing the bores or will it need a re-bore to suit new pistons, im currently out of work so trying to do it on the cheap, im a gardener at the moment so works slack, iv allways worked with cars and a good mechanic i know this sounds dodgy but would a hone suffice? or any ideas of cost of re-bore
Old Dec 12, 2009 | 03:51 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
hone should do for the bores, due to the oversize being very small the worn bores will still cause piston slap.
you should have got 0.5mm oversized pistons, then a rebore.
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
Marcus L
Aug 29, 2015 02:18 PM
Ben26
Aug 27, 2015 08:56 PM
track.focus'd
Aug 12, 2015 05:53 PM
knight19770
Aug 4, 2015 12:36 PM
