how do i make a fuel pump relay?
Old Dec 5, 2009 | 05:27 PM
john_d's Avatar
john_d
Default how do i make a fuel pump relay?
ive done a search and everyone seems different?
my relay has the usual pins
30
85
86
87
can someone please clarify what wires go where?
Old Dec 5, 2009 | 05:31 PM
oldford's Avatar
oldford
Switched by an ecu:
30 - Battery
86 - +12 when ignition on
85 - switched earth to ecu
87 - fuel pump
Drawing for a weber-marelli ecu here: http://www.siipicossu.com/manuaaleja...ediagramL1.pdf
Operated by a switch on the dash:
30 - Battery
85 - switched earth to switch to earth
87 - fuel pump
Or
30 - Battery
86 - +12 from switch
85 - earth
87 - fuel pump
Old Dec 5, 2009 | 05:35 PM
john_d's Avatar
john_d
mine will be switched by the ecu, so only pin 87 goes to the pump?
does it go to the +
Old Dec 5, 2009 | 05:50 PM
oldford's Avatar
oldford
Yes, 87 is the power supply to the pump. Earth for pump can be connected anywhere in the car. This is assuming the ecu will be switching the earth, which is very common for ecu's.
Old Dec 5, 2009 | 06:03 PM
john_d's Avatar
john_d
so
30 : Battery
86 : +12 switched ignition
87 - + fuel pump
- fuel pump to chasis
that it?
Old Dec 5, 2009 | 06:12 PM
oldford's Avatar
oldford
Yes, but you may want to add a fuse between the battery and pin 30.
Old Dec 5, 2009 | 06:14 PM
john_d's Avatar
john_d
yeah 30 i beleive?
also adding an inertia switch but not sure where that goes?
Old Dec 5, 2009 | 06:55 PM
oldford's Avatar
oldford
Usually between terminal 87 and the fuel pump.
But it also works when added to any of the other 3 connections.
Your choice.
ekjim
Aug 27, 2015 05:20 PM
Prickly_buzz
Aug 25, 2015 11:33 AM
kosienutter
31
Aug 22, 2015 09:55 AM
dlwarrior
Aug 5, 2015 10:19 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
