cossie crank??
Old Nov 25, 2009 | 03:28 PM
forevaford's Avatar
forevaford
Default cossie crank??
as title, spun number 4 bigend shell, and crank now bent apparently.
is this common? my engine made 430 odd bhp and lasted about a month! @2 bar boost and 8k rpm limmeter. am i doing something wrong? it had 2wd hp oil pump (with good pressure) and std/std crank with acl race shells. i maintain oil temp to no higher then 110 'c maybe the odd 120'c on the accasional heated moment
gutted.... do i have to go back to greens to keep it allive??
Old Nov 25, 2009 | 03:35 PM
t4 and greys's Avatar
t4 and greys
cosworth gimp
could be a million reasons why if im honest ..
was the crank a stdf/std grind????
was the bottom end balanced end to end ???
are your rods a matching set , was the crank thrust measured correctly ????
many diff reasons why ,just simply put it down to bad luck ......
not sure the yb,s like a constant 8000rpm limit often either !!!
Old Nov 25, 2009 | 03:48 PM
forevaford's Avatar
forevaford
yep, as far as i was concerned the engine was built well, but im starting to think that the limmeter is a bit high yer, bad luck it was then, lol
Old Nov 25, 2009 | 03:58 PM
pacwest's Avatar
pacwest
Puller of the Wrench
Who said you have a bent crank? Does this same person want to sell you a crank? Mechanics are sales people too...
Old Nov 25, 2009 | 05:03 PM
forevaford's Avatar
forevaford
ha, yer i no mate, he said he can get it sorted but its not the best resolution he said, so i said id try and source another first
Old Nov 25, 2009 | 05:09 PM
I would be tempted to take it to someone else to get measured for bend first.
The crank will piss 8K all day long, std rod bolts won't!!
Old Nov 25, 2009 | 07:51 PM
forevaford's Avatar
forevaford
yer thats good advice, arp rod bolts used,
i still need a crank std/std....any one????
Old Nov 25, 2009 | 09:06 PM
Alg1k's Avatar
Alg1k
Was bearing crush checked when the engine was built
I bet it wasnt !
Old Nov 25, 2009 | 11:13 PM
forevaford's Avatar
forevaford
I bet it wasnt !
nope, hows u check that? and how could u addjust it anyway??
Old Nov 25, 2009 | 11:32 PM
OldDan's Avatar
OldDan
Plastiguage
Old Nov 26, 2009 | 08:30 AM
Alg1k's Avatar
Alg1k
Originally Posted by OldDan
Plastiguage
Plastigauge is used to measure bearing clearance between crank and bearing. Bearing crush is the ability of the bearing to hold itself in the rod or block whilst being subjected to a few thousand psi without spinning in it's housing.The location tabs on the bearings don't do it all !!
Old Nov 26, 2009 | 08:31 AM
Alg1k's Avatar
Alg1k
. The bearings are fitted to the rods you then put the rod in a soft jaw vice and torque up as normal.don't hold the rod on the beam !!! You then undo one rod bolt and remove it .you then check the gap at the partline of the rod this will be or should be 2to 3 thou if not you need to try swapping bearings around to get the desired gap if youcannot get it the rod may need resizing.it's the same for the block as well .I will check for the exact size it should be I'm not 100% sure on the correct size at this moment as I'm at work.
Old Nov 26, 2009 | 08:55 AM
forevaford's Avatar
forevaford
umm thanks for the crush info, il be checking this on reasemble, thanks Alg1k
im still after a crank???? std/std
Old Feb 4, 2010 | 06:43 PM
peter/jedi's Avatar
peter/jedi
i've got a std/std crank mate i'm near watford
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
IainRS1700T
Sep 25, 2015 06:44 AM
