ERST Alternator....im confused!!
Old Nov 23, 2009 | 06:23 PM
saphcosworth's Avatar
saphcosworth
Default ERST Alternator....im confused!!
OK..have a mk2 xr2 which is fitted with what i think is an 89 ERST engine. Alternator is shafted so bought one for an escort turbo 2nd hand off ebay. Its not the same! The original has a rectangle(ish) shaped plug and the new one doesnt have any plug as such just a couple of points sticking out with nuts on. And also the mounting holes are in the same place but the tensioner bracket hole isnt. I know ive probably made a stupid mistake but any info is moocho appreciated.
Andy
Old Nov 23, 2009 | 06:24 PM
paceo's Avatar
paceo
they came with 2 types of alternator, screw on type one and a plug in type one
Old Nov 23, 2009 | 06:46 PM
saphcosworth
They deffinately not interchangable then?
Old Nov 23, 2009 | 06:50 PM
saphcosworth
This is the one off my car
and here is the one i bought
Old Nov 23, 2009 | 07:11 PM
paceo's Avatar
paceo
i think i might have a plug one mate
Old Nov 23, 2009 | 07:13 PM
phil_rs's Avatar
phil_rs
yam yammer
You can use the alternator you have bought if you change the alternator loom. It's very easy to do
Old Nov 23, 2009 | 07:40 PM
saphcosworth
sounds good, what you wantin for it?
Old Nov 23, 2009 | 07:43 PM
saphcosworth
what about the bracket the holds the tension?
Old Nov 23, 2009 | 07:57 PM
phil_rs's Avatar
phil_rs
yam yammer
Not sure about that one mate, they have always been the same for me
Old Nov 23, 2009 | 09:57 PM
IANS2RST's Avatar
IANS2RST
it will be a standard xr2 alternator as they mount hanging down where as the rst mounts upwards. rst alternator can be used but you will have to change the wiring to ring terminals & rotate the housing of the alternator itself
Old Nov 24, 2009 | 01:27 PM
The alternator you have has a lucar connector, mostly used on older brit stuff lucas etc.
There will be 2 thick red and 1 thin wire, which will most likely be blue.
If wanting to use the alternator you have bought do as said, cut off the connector, now put a ring terminal on each thick red wire, this will need to be a 8mm yellow crimp connector, put this on each wire then apply a small amount of solder just onto the terminal wire, don't let the wire wick up the solder, it only needs a small amount, then connect onto the B or B+ terminal, you need BOTH the red wires, as one won't be enough on it's own under load.
Put a 6mm red or blue crimp onto the blue wire and connect this to the "IND" terminal.
Note you will have to cut the insulation off the terminal when crimped, make sure you do this well, you don't want much solder here as the vibration could cause the soldered wire to break.
All done.
Old Nov 24, 2009 | 07:49 PM
saphcosworth
Thanks for the help folks, il give it a go this weekend if i cant source the right alternator by then.
tankybaby66
Feb 6, 2016 02:24 PM
Mc5506
Oct 5, 2015 09:57 PM
locum8
Oct 1, 2015 01:50 PM
lime
Sep 25, 2015 06:56 PM
beller
Sep 21, 2015 04:13 AM
