Escort 1982 Timing Issue
Old Nov 22, 2009 | 05:40 PM
escort1982's Avatar
escort1982
Default Escort 1982 Timing Issue
i replaced my timing belt and water pump , but when i put all togther the timinig wont line up it keep missing a few theth , im working with hynes manual and the engnie code is 1.3 JP the car is Ford Escort 1982.
i suspect that the belt is not sutable for my car ? shuld be square or round? the i have now is sqaure 92 teth and 19.75 width
what cars shares the same engine as my car ?
thnaks
Old Nov 22, 2009 | 05:42 PM
Do you not have the old belt to compare it with ?, there's defo something wrong if jumping teeth when tensioned correctly, I would at least re check the part number with supplier, I must admit I didn't think there were different teeth on this age mk3 ?
Old Nov 24, 2009 | 10:53 AM
escort1982's Avatar
escort1982
i have two old belts one is sqaure and the other is round ? the tension is o.k ? could the water pump cause this ?
Old Nov 24, 2009 | 12:44 PM
Is the pump new, if it was working ok before but now it's jumping, going out of time then likely hood is belt is wrong.
Just temporarily try the other type you have on the car.
Old Nov 25, 2009 | 09:33 AM
escort1982's Avatar
escort1982
I try it and didnt get any results , i thing that mybe something offline becuse i notecied that the belt moving out of the camshaft while turning .
Old Nov 30, 2009 | 09:28 AM
bernie0121's Avatar
bernie0121
when you are tentioning is that when timming marks are not lining up if so take pulles back about 2 teeth anti clockwise then tention belt should line up on timming marks make sure youve got tention on right side of belt cheers
Old Dec 2, 2009 | 02:13 AM
Aidan S's Avatar
Aidan S
A not so common problem that could be causing this is the tensioner is not "tensioning" sufficiently, ie, not moving enough to take up the slack in the belt. Remove the belt again and loosen off the tensioner mounting bolts, using a suitable lever, push the tensioner to the end of it's travel, see if it's sticking or fouling. Re-align the cam and crank timing marks, refit the belt, and using the lever, push the tensioner as far as it will go to take up the slack, then tighten the tensioner bolts, turn the engine over TWICE, BY HAND, CLOCKWISE as you look at the front of the engine, to make sure everything is ok, then re-check cam and crank timing marks. If all is ok, the timing marks should line up and the belt should be fully tensioned. If you still have slack in the belt, it's quite possible you have the wrong replacement belt, but as you said, you are getting the same problem with the old belt, so, one of two things, the tensioner is not adjusting enough to take up the slack, or, you have routed the belt incorrectly. Re check the belt routing against the diagram in the manual. With regards to the teeth, on the belt, the grooves in the cam/crank pulley should tell you, if you have square grooves and round teeth, or vice versa, it aint gonna work. If I remember correctly, they should be round teeth on the belt.
Vincereese
Jun 1, 2023 09:14 AM
Chas
Sep 21, 2015 08:57 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
