Help! My van won't start!
Old Nov 21, 2009 | 12:27 PM
Escow-Van's Avatar
Escow-Van
Default Help! My van won't start!
I turn the key two clicks, the pulgs light up and the electronics (radio, lights etc) all work. Turn the third click to start and nothing happens. The radio drops out as explected, but the starter motor does not come in.
So far I have tested the live feed to the motor/solenoid, that's a healthy 12.4v, starter relay (on interior fuseboard) which operates correctly, and replaced the starter motor/solenoid assembly with a new one.
Any ideas what else could be stopping it?
Any help would be very much appreciated
Thanks in advance...
Old Nov 21, 2009 | 12:29 PM
mr_joe0606's Avatar
mr_joe0606
mine does this check all the wires to the starter motor and somtimes mine sticks so just give it a couple ov taps with a hammer.
hope this helps
Old Nov 21, 2009 | 12:37 PM
Escow-Van's Avatar
Escow-Van
I should probably have said, when I turn the key to the third click, the starter relay does not activate. Also it is a brand new motor and solenoid, so I hope it doesn't need hitting with a hammer.
Thanks for your help though Joe, any other ideas?
Old Nov 21, 2009 | 01:29 PM
Escow-Van's Avatar
Escow-Van
Also forgot to add, it bump starts fine and runs perfectly after then. Ideally I don't want to have to park on a hill for the rest of forever though
Old Nov 21, 2009 | 01:33 PM
mr_joe0606's Avatar
mr_joe0606
somet up with the wireing i would persume mate a bad connection somewhere
Old Nov 21, 2009 | 01:54 PM
stickertone's Avatar
stickertone
check your engine earths.... if its got 12v the positive is ok an battery not flat.. so try earth. you could put a jump lead from battery (neg) to engine.....
Old Nov 21, 2009 | 02:18 PM
Escow-Van's Avatar
Escow-Van
The engine block and gearbox both bell out to the negative terminal on the battery. The relay which pulls in the solenoid and starts the motor does not activate when the ignition switch is turned. Any ideas what might cause this? The relay works fine on the bench.
Old Nov 26, 2009 | 10:02 PM
Escow-Van's Avatar
Escow-Van
Took it up to the local garage, they found it to be the fuseboard PCB that had popped! Replaced, its all working fine now
van_dogg_pavvy
Mar 3, 2016 09:30 AM
orion88
29
Feb 16, 2016 08:47 AM
Bailes1992
Sep 3, 2015 02:17 PM
jonjg
Sep 1, 2015 03:46 PM
vdubo7
Aug 2, 2015 08:17 PM
